Jensen CDH1000 INstallation help
This is a big question. A little more info would help. Are you running any typ of amp? Is there a ATT, or MUTE button on the radio? Are you running it through factory wires? Check the fader and balance make sure they are set right. Hook up the power and ground to the radio. Then get an extra speaker and hook it up to each set of outputs (speaker wires off the back of the radio) and see if it works. If all the above does not work TAKE IT BACK.
hey man jensen just sux but yeah check for a mute button and check ur power and ground connections or the factory wiring could be screwed up check these and if this dont work take that ******** back
sorry to bump an old thread!
HA! :hilarious Lol
That's comming from a guy who's running Pyramid. I'd take Jensen over Pyramid any day!
No. Unfortunately, this seems to be a common issue with the Jensen Car1000. I have one that is less than a year old that gets stuck some days. I...
Not to deflate your ambitions, but here is a reference: https://www.simplyspeakers.com/Altec-6-x-9-3-Way-Auto-Speaker-Sold-Out_p_639.html Not...
Crutchfield is really good about that sort of thing. Not the cheapest prices but you know where your money went if you ever have any technical...
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
9
Disconnect the amp for a day or two, then connect it back up. If it stops draining when unplugged then drains again, take it back and have them...
trumaster
trumaster
Chicago
91explorerV6
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
