JL 450/4 to power whole system
theimpaler
Ive decided to redo my entire system. Im no longer in the need of loud bass that shakes my car. Im looking for clean tight music that will stay inside the car. Personally I don't want people outside to be able to hear it.
I just ordered a JL 450/4 and am planning on running some components up front with the 3 and 4 channels of the amp. They are rated at 75 watts rms 1.5-4 ohms.
I am going to bridge channels 1 and 2 for 300 watts rms 3-8 ohms and run either a pair of 6x9 subs or 1 8" sub. How does that sound?
Does anyone have any experience or thoughts about the JL 450/4? I managed to pick it up for an even 600. :readytogo
don't run 6x9's they distrot at high volumes. Run a comp set with channels 3 and 4 and then run 2 re 8's of the first two chnnels
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Certainly depends on the vehicle and type of enclosure tuning for the subs and direction of the subs and port to begin with, then power...
7
191
If you are using an aftermarket headunit, make sure your subwoofer is set to 'on' in the settings menu
4
233
theimpaler
theimpaler
Louisiana
Berry47
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
