JL Audio 12W1v2-4 & MTX Thunder6000 T6104A
JL Audio 12W1v2-4
For full specs: JL Audio 12W1v2-4 W1v2 Series 12" 4-ohm subwoofer at Crutchfield.com
Has a small dent and a little rust, runs like new.
12" 4-ohm subwoofer
metallic-finish polypropylene cone with nitrile-butylene rubber surround
power range: 50-300 watts RMS
peak power handling: 600 watts
frequency response: 22-200 Hz
sensitivity: 86.81 dB
top-mount depth: 5-1/8"
sealed box volume: 1.25 cubic feet
ported box volume: 1.75 cubic feet
For full specs: MTX Thunder6000 T6104A 10" 4-ohm Component Subwoofer at Crutchfield.com
asymmetrical linear drive system (ALDS) — spreads stress evenly across the suspension for high output with low distortion
mica-filled poly cone coated with spun aluminum with 8 stiffening ribs for extended power handling
progressive spider design with an extended pole piece with a flared vent for smoother sound even at ultra-high sound pressure levels
one-piece gasket/surround made of thermal-pressure-formed Nitrile Butadiene Rubber (NBR) for superior sonic accuracy and greater overall durability
frequency response 31-150 Hz
power range 50-250 watts RMS
peak power handling 500 watts
sensitivity 85.2 dB
top-mount depth 5"
sealed box volume 0.5 - 1.0 cu. ft.
ported box volume 1.0 - 2.0 cu. ft.
JL Audio 12W1v2-4 $75
MTX Thunder6000 T6104A $20
Shipping is at cost (in the area of $15-$20) or if you're around the Ann Arbor Michigan area I can meet half way at no cost. Pay via paypal
For higher resolution pix check my imgur album Craigslist sale - Album on Imgur
View attachment 26553118View attachment 26553117View attachment 26553119View attachment 26553120View attachment 26553121
JL Audio 12W1v2-4
12" 4-ohm subwoofer
sensitivity 85.2 dB
top-mount depth 5"
