JL Audio 500/1 and Kicker L5 15" problems Turns off
HummerGeorge
Well I had my JL 500/1 Hook up to a L5 15" for about 6 months now without a problem till now. When I crank up my bass my sub turns off but my amp is still on but the LOW amber light comes on. but it takes a real long time for it to turn back on it took 1 day for it to come on ? That day I was trying it every hour with no luck until the next day, Its a very werid problem I would like some help on this ? Stereo shops here said its the amp, then the other one said its the woofer, and said it needs a cap.
Please helpppp
Thanks George
Well you can check the woofer with an ohm meter. Get one and check to see if it falls in the specified Ohm range of the speaker.
If that is good, then get the volt meter and turn your stereo on, and test the power draw at the amp's Pos and Neg inputs. With the car running it should be between 14.7 and 12.5. ( I know 12.5 is low but it will still work) If you voltage is dropping below 12 you have a problem with either you power input, or you ground area.
It is really hard to give you a good answer with all the posabilities. But if you amp and sub are under warrenty then I would send them back in when you find you the problem.
my RE SE ($200) graphs (using BBP) lay right on top of the 12w6v2 graphs JLs good stuff but $$$
128
1.3cuft isn't enough airspace. Shredders box plans are simple enough if you want to save a couple bucks.
10
174
Hey all! So new here and NOT new to car audio...but it's been a VERY long time since I've messed with it. Used to build some crazy setups...
HummerGeorge
HummerGeorge
Santa Rosa, CA
pavengmike6
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
