Kenwood DDX470 to pioneer GM-D9605 amp wiring questions
Eagles512
Having a bit of trouble finishing my install. I have the kenwood head unit going to my pioneer 5 channel amp using the middle RCA slot on the HU and the left (ch A) on the amp. Right now the tweeters and mids work great but if I use the HU to try and use only the front or rear speakers it screws up. If I select "right" then only the tweeters play. Rear plays all 4 and front plays the doors mostly but still play the tweeters too. My question is, do I need another RCA cable going from the right slots on the HU so the middle and right ones will be used and plug those into the ch A and ch B RCA inputs on the amp? And then run the sub off the head unit using the 2 sub. Out plugs and put that into the SW ch on the amp? So all 6 red/white plugs will be used on the amp?
Right now since it's only one cable from the HU, I have the amp switched to the 2chan mode instead of 4 chan. Just trying to figure out how to wire all 5 speakers and get the most sound out of them. Thanks for any help.
I think if you have space on your phone (ability to use an external micro usb storage card) you could use your phone to stream HiRes music to the...
349
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
Eagles512
Eagles512
Charlott, nc
Eagles512
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
