kenwood kac 8401
  • 2
1000w kenwood kac-8401
ok so i just recently acquired a 1000w kenwood kac 8401 4chn amp. now im going to use it to power one single 12in pioneer shallow mount and my two alpine 6.5's in my doors first off has anyone had any experiance with these amps?
..now the dumb part i have never wired a 4chn amp before only mono how do i wire it up. as far as bridging for the sub. it has a front and rear speaker terminal and front and rear rca inputs do i need to run two sets of rcas? for my door speakers?
any help would be great.
are you wanting to run ur entire set-up of this amp?
run channel 1 to one 6.5"
run channel 2 to the other 6.5"
then bridge channels 3 & 4 to your sub.
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
811
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
985
4thgradedropout
4thgradedropout
st.peters,mo
4thgradedropout
ttt123
    Jul 2, 2024
ttt123
    Jul 2, 2024
