kicker kx 600.1 questions
  • 1
yotabass
ive had a kicker kx600.1 amp installed for over a year with no issues . as of 3weeks ago i broke the rca cable and didnt have another but did have a line converter so i installed that ,no issues there either. now this morning for some reason the protection light is on ,amp doesnt work, and every so often it tries to get power but goes right back to protection. i put an old 600 bazooka in and that seems to run fine. any ideas whats up with my kicker?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
yotabass
yotabass
lanc,pa
yotabass
AnthonyO
    Jun 30, 2024
AnthonyO
    Jun 30, 2024
