Lack of balance between front component set and rear 6x9's
PollyCranopolis
Bees!
Power: RF Power 851x highs, RF Power 1001bd lows.
Deck: Alpine CDA 9805
Speakers: Lows - 2 Audiobahn Natural Sound 12's, DVC
Highs/Mids - Audiobahn ABC 600T components, front
Audiobahn 6x9's rear
Highs all run 4 ohm stereo.
Problem: Having trouble getting front components to keep up with rear 6x9's. Crossovers for front/rear set at 140. highs at deck set flat, 12.5k, (dropping to 10k seems to put out too much hiss) bass flat, freq set at 100, bass eq set to 4
My problem is that I can't get even sound up front from the component set. Rear 6x9's set at lowest gain setting at amp still overide front components set at 1/3 gain. Cranking the gain on the front much higer, and the tweets start to distort. I know those components can take a hell of alot more power than the 6x9's, but like i said, cranking the gains up on the components to the point where they seem to be able to keep up with the rear, and the tweets start to hiss and distort. Looking for some advice on how to alieviate this problem. Diffrent crossover settings at amp? higher treble settings at deck? Thanx:p
We don't have enough info, but I'm pretty sure you got something out of phase. When you fade to one side or the other the phase issue disappears.
8
584
I downloaded 2 db readers for my phone to see how loud I listen to my music. Sadly they both tapped out at 95db. So for a 10min drive they both...
25
3K
Simply put its an oldschool simple way of keeping the midbass in phase with each other when they are firing at each other in the front...
829
I was about to ask the same thing. Why would you want to wire the batteries in series. But then you said you were connecting them to the same...
5
287
PollyCranopolis
Bees!
PollyCranopolis
Frostburg, MD
desi_daru
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
