Line out converter problems!
  • 1
Ras3
Well I decided to rewire my car today and bought a new line out converter I hooked it up correct to both rear speakers + and -. My system worked fine before but now when I crank it up my indoor speakers plus sub cut off but when I open the trunk the system comes back on??? The only thing that I changed was the line out converter and the wires from the deck speakers to the LOC. If I used to small of a wire running from the deck speakers to the LOC would that cause a problem?
How did you tap your existing wires? I don’t trust Posi-Taps or anything similar for the long haul. If you used them, try removing them and...
8
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
  • Locked
Cerwin Vega IOEM8 8ch line converter for sale, bought brand new as A-stock last summer. Mounted to baffle in preparation for installation but...
Update. Took line out back and just upgraded my head unit. Now my sound only plays when fade is in rear and balance to left. Ugh. One thing after...
20
3K
Ras3
Ras3
San Antonio, Tx.
Ras3
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
