nastety92
Hello all,
My name is Nick and this is one of my first post on this forum. I use to be much more into car audio before kids and a house. I'm looking to put a small system in a 2003 Yukon that I just purchased. To start I would like to just add a 10" sub and keep the Bose setup. I'm trying to find a sub that will work in a sealed enclosure and will work with the amp that I have left over from another vehicle.
The amp is an Alpine MRD-F752. I actually have two of these, one us used and one is brand new in box from around 1999-2000.
Here are the amp's specs.
5 Channel class T Amplifier
RMS power Channels 1-4 at 12V, 20Hz ∼ 20kHz:
4 x 75W @ 4 ohms (0.08% THD)
4 x 100W @ 2 ohms (0.3% THD)
2 x 200W @ 4 ohms bridge (0.3% THD)
RMS power Channel 5 at 12V, 20Hz ∼ 20kHz:
1 x 250W @ 4 ohms (12V - 0.3% THD)
Freq. Response: 20Hz ∼ 20kHz (+0,-1dB)
S/N Ratio: 100dBA (at rated power)
Fuse: 80A
Dimensions: 17.9" x 10.2" x 2.4" (46cm x 26cm x 6cm)
Weight: 18.5 lb. (8.4 kg.)
Thanks for the help,
Nick
Fuse: 80A
Nick
