Mazda 6 i2.3 need help...
Cutchman
Ok so I have a bone stock 2004 mazda 6, 2.4 and I need some help real bad. So I had a previous car that I had a small 10 inch sub in, real simple set up and now that I have a new car and more room I want to upgrade. I have someone that was basically giving away 2 kicker comp 03cvr124 dual voice coils in a sealed box and a Sony xplod 1100 watt xm-d500x, and I was wondering if my stock 90 amp alternator would push that amp. I was thinking about getting a capacitor to go along with the amp to help my alternator. So my main question is is that amp enough for the speakers 03CVR124: 12" 4-Ohm Dual Voice Coil Comp VR
03CVR124 Features and specifications:
mica-filled polymineral cone
Santoprene rubber surround
dual 4-ohm voice coils for wiring flexibility
frequency response 25-500 Hz
power range 50-400 watts RMS (200 watts RMS per coil)
peak power handling 800 wattsand would it be OK to run all of this off of the stock alternator
Sony Xplod Mono Amplifier, Model XMD500X
Features:
1100W max power
250W x 1 RMS into 4 ohms, 20Hz - 100Hz at 0.2% THD
500W x 1 RMS into 2 ohms, 20Hz - 100Hz at 0.6% THD
Class D
Variable 50-300Hz Low Pass Filter
40Hz EQ boost
Line level through-put
MOSFET output stage & power supply
RCA & speaker level inputs
Specifications:
Circuit system: Class D Technology
Power supply: Pulse
Maximum outputs: 600 W (at 4 ohms)
Maximum outputs: 1100 W (at 2 ohms)
Rated outputs (at 14.4V): 250 W (20 - 100Hz, 0.2% THD, at 4 ohms)
Rated outputs (at 14.4V): 500 W (20 - 100Hz, 0.6% THD, at 2 ohms)
Frequency Response: 5 Hz - 300 Hz (±3dB)
Harmonic distortion: 0.04% or less (at 100 Hz, 4 ohms)
Input level adjustment range: 0.3 - 6V (RCA pin jacks), 1.2 - 12V (High level)
Low-pass filter: 50 - 300 Hz, -12 dB/oct
Low boost: 0 - 10 dB (40 Hz)
Inputs: RCA pin jacks, High level input connector
Outputs: Speaker terminals, Through output pin jacks
Speaker Impedance: 2 - 8 ohms (stereo)
Power requirements: 12 V DC car battery (negative ground)
Power supply voltage: 10.5 - 16 V
Current drain: 62 A (at 2 ohms, rated output)
You'll be fine, don't do any other upgrades. If the alternator fails then make he investment on additional parts. I doubt you'll have a problem.
My 06 held up to 1200w fine with no big 3 or anything so youll be fine. And that person was giving that away because you can only wire the 2 subs into 1 or 4 ohms so youll have to run the amp at 4 ohms since it is not 1 ohm stable. I suggest get a different amp that is 1 ohm stable
If you can tap before the Bose amp, then you may only need a simple LOC. If you tap after the Bose amp, then you will need a bass restorer/LOC...
I was looking today behind the dash to llok at the wires..I have absolutelly no idea what they are for .i know only power 12V,ACC and ground ..the...
4
435
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
537
Cutchman
Cutchman
Indiana
C1500martin
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
