more bass
the EQ and X-over will give you the ability to "boost" the signal in a specified range, but I doubt it will help your bass woes. If your amp(s) isn't giving your sub(s) enough power, or you don't have enough wooferage, you will probably have to upgrade. Imagine a 400 lb guy trying to climb a 8-foot fence(thats your system), now you get a 140lb guy(EQ or X-Over) to give him a "boost", chances are the little guy can get the big guy over, but its gonna be real sloppy, and probably break the fence and some bones. EQ's are designed to flatten out the response curve and do some fine tune tweaking for personal tastes, Caps are used good for holding heavy doors open, and X-overs split freq's into different sections and send those signals to the amps/speakers. If you let us know what you're banging, we can help you better.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
cvance383
cvance383
jacksonville, FL
supraman1379
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
