MTX ReQ or Crossover
  • 2
kirk
14
Dyer, IN
I want to install my amp and sub in my new truck, the amp is old school PPI Art Series that doesn't have a built in Xover. I want to keep the factory head unit and I'm confused about what I should get. The MTX ReQ or a 2 way Xover such as the Kicker KX2 hooked up with the Hi-Level inputs from the factory system. I'm not looking to rattle the windows but to just fill in the bottom end a little. Any help you guys can give me would be appreciated.
Kirk
depends on what year the truck is. the newer ones have a bass reduction built in and your gonna need soemthing to flatten that out. the mtx req does that. seeing how the ppi don't have built in xover i'd look into something like the Audio Control DQL8
Thanks for the help Horsemanwill...I'm just going to use the amp for the sub and I believe the ReQ has a 40-200HZ subwoofer xover.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
909
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
3K
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
kirk
kirk
Dyer, IN
Horsemanwill
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
