My HU went out
Brooklynchild07
my car cd player went out one day while listening and I changed the fuses in my cd player (which was already brand new) and the fuses for the accessory panel too. So basically all the fuses are replaced. I also checked my cd player in my friends car to see if it works and it does. I'm guessing maybe the car wires burned out or something but it is obvious that it has to do with the connection between the battery and the cd player. Any suggestions?
check for fuses like these to be bad:
cig. lighter
courtesy light
interior light
backup
radio
check both the fuses inside the car and the ones under the hood in the engine compartment as well.
I feel like that is more of a result of the cabin gain of your car and box size rather than tuning frequency. If the box is massive there will be...
12
570
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
6
Brooklynchild07
Brooklynchild07
Charleston, SC
Pete
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
