My subs are cancelling each other out
NaztyNate
Wyoming
I have been into car audio for a couple years and know my fair share. I pretty sure I know whats going on but don't know how to fix it or if I can fix it.
I have 2 Infinity Kappa Perfect 12" subs that used to both be in .85 Q-Logic boxes. I recently purchased a thunder box 1x12" bandpass box and put one of the subs in that box. The one alone is as loud or louder as the two before and the SQ is not bad for bandpass, but when i hook up the other one too they seem to cancel each other out. The one in the bandpass is louder than it and the other one in the Q-Logic combined. I know there is enough power to them because they are each gettin 300rms and they take 350. Plus i have moved them both around in my trunk and it hasn't seemed to help.
Any help would be aprreciated.
Happens to the best of us man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Enjoy your system.
These are custom built using triple stacked y35 motors with cross drilled back plates and vented pole pieces which are also radially drilled for...
You can connect subs with wires in different ways and that can change the ohms (resistance) the amplifier sees. Too low of a load (closer to 0)...
384
Aw.... You're talking about good ol' Mich.
15
745
Both in the right box are good. Those premade ones probably don't give you their potential. I wanted to try one of those R subs but man Alpine...
5
479
The way you had them before does not really pose a danger. On the contrary, they presented a higher Ohm load to the amp so the amp put out less...
407
NaztyNate
NaztyNate
Wyoming
nosaj070
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
