my system and price/good or "run for the hills?"
lcoomes59102
Okay, got the Premier DEH-P350 hu, thinking of going with the Eclipse SP8962 6.5inch for the doors, SP8942 4X6 in the dash, then it's a choice between the Alpine SWR1041D sub or Infinity 1030W. (1 sub only)
Powering this set with the Alpine amps, #MRPF240 mono for the sub, and MRPM350 for the rest.
All this for an '03 chvy S10 ext cab, and priced @ $700, or so, depending on which sub I go with.
How's the setup sound to you, and is the price okay?
Sounds like a good plan to me. How much are you gonna spend on either of the subs. You may consider getting an Elemental e10k, I believe they are $75 right now. And why not go with a dual sub set up since you have an ex-cab.
Could go w/2 subs, but I just don't hit the bass all that hard. Actually, the midbass a decent 6.5 puts out is usually enough for me, so I think one sub should be more than adequate.
I have only one jump seat, (gonna remove it) and even w/an alarm want to hide my sub and amps, due to living in a high crime area. Easier to hide one than two, right?
I would also recommend checking all the amps wiring to make sure secured/ tight and ground is solid and remote making solid contact in the terminal
7
437
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
500
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
836
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
lcoomes59102
lcoomes59102
Seattle, WA
skeetskurt
ttt123
    Jul 2, 2024
ttt123
    Jul 2, 2024
