Bronzefish72
CarAudio.com Newbie
I have a 4 channel amp (see specs below) and 4 wakeboard tower speakers rated at 150w rms / 300w peak. I want to run the speakers in parallel (unless series is better). The speakers are 6.5" with 1" dome tweeter. I am not sure if my amp is proper for my intended setup and need to know if I should buy a 2 ch amp instead. Per the vendor I bought the amp from, I was told this amp won't work for my setup and I should purchase a high power two channel amp instead.
Here are the specs of my 4ch amp:
• CEA Power Rating: 260 Watts (4 x 65 Watts) @ 4 Ohms and 1% THD+N • RMS: 800 Watts (4 x 200 Watts) @ 2 Ohms • RMS: 2 x 400 Watts @ 4 Ohm Bridged Mono • Peak Power: 1600 Watts • Minimum THD at Rated Power: <0.05% • Frequency Response: 10Hz - 40KHz • Sensitivity: 100dB @ 1w / 1m • Damping Factor: > 200 @ 100Hz • Three 20 Amp Maxi Fuses • Dimensions: ( W x H x L ) 8.6˝ x 2˝ x 13.7˝
• Crossover Band-Pass Control • Fully Adjustable 12dB Bass Equalizer • 2 Ohm Stable Stereo • 4 Ohm Mono Bridgeable • 3 Channel Mixed-Mono Capable • Mute and Delay Soft Start System • High Level Input with Smart Auto Turn-On • Full IC-Controlled Protection Circuitry
Because the amp is rated at 4 ohms when bridged, I apparently can't run my 4 ohm speakers in a pair a parallel as that presents a 2 ohm impedance per pair. I would be doing 2 speakers in parallel, one pair for left and one pair for right (not doing all 4 in parallel to one channel.)
So can I safely bridge channels 1&2 for the left pair in parallel and then bridge channels 3&4 for the right pair in parallel? The vendor is suggesting I purchase a comparable output amp but with only 2 channels instead of 4. This leads me to believe I can only bridge one set of channels on this amp.
I currently have a pair of 14 awg wires pulled through the tubing of the wakeboard tower. I don't want to drill and pull 2 more wires as there are other existing wires I'm contending with. I realize 4 separate speaker wires would be the best route here, but it's not a practical solution due to wiring limitations. I called a local stereo shop and was told I can safely bridge ch1&ch2 AND simultaneously bridge ch3&ch4.
