Need help - cd stuck in cd player
think of it this way... its obvious that the radio is broken, and i'm assuming that it is not under warrenty. hammer time. beat the hell out of it with a hammer. if that fails, take every visible screw out until you reach the cd
I had this problem once. If you havent tried yet. Turn off the unit and turn it back on holding the eject button. Or try other ON/OFF functions.
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
539
Killamat and Siless is the same thing. You don't need the thickest stuff either. You're not competing in any DB drags. The 50 mil will be just...
498
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
WANTED Need Help
I definitely always wanted a set ....dual had a set also the XF series I believe ...it had the red aluminum cone with big surrounds ...I've ran...
794
plin6
plin6
Indianapolis, IN
amedeuce
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
