need help: setting my crossovers...
allyourblood
kill the fakes
okay, i've got my subs' crossover set at 80hz (LPF). does this mean my 4 interior speakers should be set at 80hz (HPF) as well, to take over from that point on, or should they be set around 250-300? it seems the C/Os should be set adjacent to one another, but something about that doesn't feel right. but if i set the 4 speakers higher, it seems as if i will miss those frequencies in between.
as in my sig, i've got 2 6.5"s in the front, 50wrms. 2 6x9"s in the back, 60wrms. perhaps i should set the rear crossover lower than the front? i'm stumped. help!
abe m.
Setting the crossovers to the same freq is a good starting point. From there you can fine tune it to get it to sound how you want it to. You might want a bit of a gap to tame a resonance or a bit of an overlap to help with a frequency trough. If you have access to an RTA that can be helpful by letting you see the effects of the changes you are making.
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
539
Killamat and Siless is the same thing. You don't need the thickest stuff either. You're not competing in any DB drags. The 50 mil will be just...
498
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
allyourblood
kill the fakes
allyourblood
San Diego, CA
tobz
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
