need help with bx1500d amp hookup
ckarls2000
I just bought the BX1500d amp. and it will be powering 2 L712" Kickers at 1 ohm.
I was told it would be good to go with 4 ga wire.
What else do i need to hook up the amp?
I know i need a fuse and a battery terminal thingy but what exactly should i get? and what would be a good location?
Is there anything else that i will need to get besides speaker wire and the inputs from the stereo.
Is there any recommendations?
the above would be good. Wal Mart also sells a very nice 4ga kit, with everything you need, ie: terminals, wiring, flex loom, fuse, zip ties, etc... (and a little more - it comes with a distro block and wires you could use if you add another amp in the future) for $25.00.
abe m.
so will the wal-mart wiring kit have all i need fuse wise?
i already have the rca cables and signal wire.
the 4 ga amp kit at knukonceptz.com says that it has an 80 amp fuse is that enough for a 1 BX1500d amp. if not can i still hook it up without having to buy new parts?
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
537
Killamat and Siless is the same thing. You don't need the thickest stuff either. You're not competing in any DB drags. The 50 mil will be just...
498
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
WANTED Need Help
I definitely always wanted a set ....dual had a set also the XF series I believe ...it had the red aluminum cone with big surrounds ...I've ran...
794
ckarls2000
ckarls2000
Everett, WA
DJ FURY
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
