Hi, within the next couple of days I'll be ordering a couple of Kicker CompVR 03CVR124 12" subs. I'm just wondering how I should be wiring these subs with my Kenwood KAC-929 1000w amplifier? Here are specs for the amp and the subs:
and the Kicker CompVR's:Two-channel power amplifiers such as the 150 watt x 2 channel KAC-929 2-Channel Power Amplifier are hard to beat.The bridged rating of this amp is 460 watts and the maximum output rating is 1000 watts. Included Features are tri-mode operation, a variable low-pass crossover, selectable bass boost, a dynamic expander, and 2-ohm stability. Also included are speaker level inputs, speaker relay protection circuitry, and a Quiet Turn-On circuit.
- GENERAL FEATURES Ground Isolation Circuit
- Low-Pass Electronic Crossover
- Power MOSFET Switching Power Supply
- Stereo, Mono, or Tri-Mode Operation
- Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
POWER RATINGS
- Bridged Power Output at 14.4V (1kHz, 0.8% THD): 460 Watts x 1
- Maximum Output Power: 1000 Watts
- Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 230 Watts x 2
- Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 150 Watts x 2 AUDIO FEATURES
- Quiet Turn-On
- RCA Audio Inputs: Gold-Plated
- Speaker Connectors: Gold-Plated, Screw-Type
- Speaker Level Input Terminals
- Speaker Relay Protection POWER SUPPLY FEATURES
- 2-Ohm Stable
- Black Powder-Coated Top Cover: with Sandblast Finish
- Copper EE-Core Power Transformer
- Large Aluminum ID Badge
- Noise Supression Filter: 3
- Power Indicator: Blue
- Power Input Terminals: Gold-Plated, Large Screw-Type
- Secondary Capacitors: 2 Large AMPLIFIER FEATURES
- 2 or 1 Channels of Amplification
- Cooling Fan
If I understand this correctly, I should wire each sub to a seperate channel right? And this would cause a final load of 2 ohms resulting in 230 watts of power going into each sub? I've read on here about people being able to wire in parallel and end up with a 1 ohm load even though their amps arent listed as stable 1 ohm. Would that be possible with my amp? Any help is appreciated, thanks.Subwoofer Specifications
* Size: 12 inch
* Rec. Sealed Box Dims: 1.00 - 4.60 cu.ft.
* Rec. Ported Box Dims: 1.75 - 2.25 cu.ft.
* Free Air Usage: not recommended
* Sensitivity: 86.4 dB
* Frequency Response: 25-500 Hz
* Recommended RMS Power: 400W
* Peak Power Handling: 800W
* Impedance: dual 4 ohms
