Need help
Dj-torn
Still learning...
I have a 2002 Camry and have placed 4 Pioneer TS-A6990R in place of the factory speakers. I am looking for the best way to power these speakers, and trying to keep a pioneer theme to the car, but i'm not to sure what amp to go with...Anybody have some suggestions??
Thank you
:up2someth :up2someth
I have a the factory installed head unit still installed and i haven't had a chance to take it out and look at what i got going on in the back.
The speakers have a resistance of 4 ohmes and are rated at 80W RMS
Be carefull how much power you feed them. I also used to have 4 Pioneer speakers and they always handled fine when i used my Jensen and then a Clarion amp. Both were 50 x 4 amps, then i used my PPI 50 x 4 amp, and the speakers fried. They sounded AMAZING for about a day, then i heard this crackle and a strong smell of Crazy glue, and the speakers sounded terrible after. And the speakers were rated at 50wrms, but apparently could not handle it.
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
543
Killamat and Siless is the same thing. You don't need the thickest stuff either. You're not competing in any DB drags. The 50 mil will be just...
499
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
WANTED Need Help
I definitely always wanted a set ....dual had a set also the XF series I believe ...it had the red aluminum cone with big surrounds ...I've ran...
796
Dj-torn
Still learning...
Dj-torn
Fairchild, WA
Breogan24
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
