Need Help
Devilsob
20
NY
hello, i have a Rocksford Fosgate Amp 601s, Kicker S15L7 - 2 ohm Sub, 4X Infinity 6802cf 5x7 6x8, and a Alpine CDA-9813 Head unit..
heres my question, what kinda wiring do i need. ? i have a 94 mustang.
y dont you want to install it yourself its much cheaper and you learn how to do something new, your also going to need more wire for the head unit to the infinitys i would recommend 16 gauge wire from wal-mart, the cost for the amp kit and the 16 gauge wire i think would be around $35-$50 if you buy your stuff from walmart
first of all, thanks for responding to my post.
ill get the 4 gauge amp kit, and some extra wiring( 16 guage wiring, anything else? ). i was reading some post, and do the wiring make a big diffrance?
Buy a complete amp kit from http://www.knukonceptz.com
You should be able to get away with an 8 gauge kit, but if you plan on ever upgrading, you might as well go for the 4 gauge kit now.
BTW, wiring stuff is easy. Don't waste money by having a shop do it. If you need help we can give you steps.
can you guys give me some steps , on how to install this stuff. BTW i dont have a box for my sub.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
im a newbie at this stuff //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
so are u going to install it yourself or are you going to get an audioshop to wire it, if you get it wired by an audioshop how much will they be charging you
he said from 100-150. but i got a friend who does this stuff. hes doing it for free //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif , next sat.
thats good how much did the wires cost you, you should watch him do the install it will show you how easy it is to make a good install
theres 2 of them, dont know witch to pick
Rocksford Fosgate
two 5-meter (16.4-foot) purple Stealth patch cables
17 feet of 4-gauge translucent red power cable
3 feet of 4-gauge translucent ground cable
6 feet of 8-gauge translucent red power cable
6 feet of 8-gauge translucent ground cable
38 feet of 16-gauge speaker wire
platinum-plated fuse holder with 60-amp AGU fuse
platinum-plated fused distribution block with 30-amp fuse
platinum-plated ground distribution block
2 platinum-plated ring terminals
17 feet of 18-gauge tinned silver turn-on lead
16 spade lugs
16 female disconnects
wire ties
protective
or.. Store Brand..
1) 25FT RCA DIGITAL INTERCONNECT AUDIO CABLE, TRIPLE SHIELDED WITH BUILT-IN REMOTE TURN ON WIRE AND RIGHT ANGLE ENDS FOR A TRICK INSTALL.
(1) 4 GAUGE 20 FT RED POWER CABLE (HIGH QUALITY)
(1) 4 GAUGE 4 FT SUPER GOLD GROUND CABLE
(1) 35FT OFC 12 GAUGE SPEAKER CABLE
(1) 20FT BLUE REMOTE TURN ON WIRE 16 GAUGE
(1) 80 AMP GOLD PLATED AGU FUSE
(1) 4 GAUGE GOLD RING TERMINAL
(1) 6 FT 4 GAUGE BLACK SPLIT LOOM FOR CABLE PROTECTION AND ORGANIZATION
(4) FEMALE DISCONN. 14-16GA, 1/4"
(2) RING TERMINALS 4GA ID:S/16"
(2) SPADE TERMINALS 4GA ID:10#
(5) SPADE TERMINALS 14-16 GA.ID:8#
(3) SELF TAPPING SCREWS
(5) RUBBER GROMMETS
(20) BLACK CABLE TIES
(2) BUTT CONNECTOR 18-22GA RED
(1) BUTT CONNECTOR 4GA RED
the Rocksforg Fosgate cost 50 bucks and the Store Brand cost 25..
Rocksford Fosgate
16 spade lugs
wire ties
protective
or.. Store Brand..
(5) RUBBER GROMMETS
forgot to mention , that someone added that i needed some more 16 guage wire.
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
539
Killamat and Siless is the same thing. You don't need the thickest stuff either. You're not competing in any DB drags. The 50 mil will be just...
498
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
WANTED Need Help
I definitely always wanted a set ....dual had a set also the XF series I believe ...it had the red aluminum cone with big surrounds ...I've ran...
796
Devilsob
Devilsob
NY
78nova
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
