Need some opinions other than my own!
dawgs007
Low-End Fanatic
72
Ohio
I am helping a buddy install 2 12" P1's in his 2008 G6. He has to remain using his stock HU, so what would you guys suggest to be the best way to wire subs up? Note: his HU doesn't have any RCA-outs. It's all speaker level. I thought of tapping into his rear speakers and using a LOC, but didn't know if that'd work. Thanks in advance guys!
I don't think he has any intentions of swapping out decks anytime soon. Also, would splicing the LOC into the rear speakers decrease the performance of the rear speakers?
Alright, thats my intention at the moment. I've never hooked up a sub system without an aftermarket HU. Hopefully it goes well!
So, before I begin the install in the next couple of days... It is, in fact, possible to tap into rear Monsoon speakers with a simple LOC to allow RCA input for subwoofer amp?
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
543
Killamat and Siless is the same thing. You don't need the thickest stuff either. You're not competing in any DB drags. The 50 mil will be just...
498
At full power, you will be drawing about 450 amps. However, I doubt you will be pushing your system that hard. So, that being said, I would use...
491
WANTED Need Help
I definitely always wanted a set ....dual had a set also the XF series I believe ...it had the red aluminum cone with big surrounds ...I've ran...
796
dawgs007
Low-End Fanatic
dawgs007
Ohio
dawgs007
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
