Need wiring help
kisswahili
ATL
theres 2 SVC 4ohm subs 200 watts RMS each
theres a 2 channell amp with different wiring options.
when bridged gives 400 x 1 @4 ohms
or
200 x 2 @ 2 ohms
or
100 x 2 @4ohms
Now when i wire the subs parralel i get a 2 ohm load..leaving me with 2 wires to run to the amp.
How do i wire the subs to each channell of the amp so it can see 200 x 2 @2ohms or how can i bridge it to 4 ohms and still run the 2 wires after bridging to each sub?
check out this posting under Wiring, Electrical and Installation Help > voicecoil wiring options. There's a good diagram on how to wire them up
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
6K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
5K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
kisswahili
kisswahili
ATL
mrburner
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
