SOLD New 220a Ford 3g Mustang 5.0 3.8 Altermator T-Bird Cougar
Louisiana_CRX
dem shoes......
This is a brand new high quality 220amp Ford 3g alternator...It will fit 87-95 5.0 Mustangs...the 87-93 require slight mods to the bracket and 94-00 3.8 Mustangs...It will also fit the 3.8 Thunderbird /Cougar 94-97 $200 priority mail shipped CONUSwill consider some trades...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
AnthonyO
    Jun 30, 2024
AnthonyO
    Jun 30, 2024
