new amp....?????????'sss
Sleeklsc
mtx 1501d, got the amp today only because the people didn't have the rf 1501bd...anyways here are my ?'s
1)is the ebc (bass controller)neccesary ................. (meaning like that i wont be able to adjust the "bass boost" without it)
2)the birthsheet states that it puts out 1147 rms at 2 ohm at 12.5 v... i would think that number would increase if a car is putting out 14+ v right...if so what total rms am i lookin at...or a guesstimate...
3)"the phase select switch allows you to invert the phase by 180 degrees at output" what does that mean?what does it do?
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Did you integrate the C60 between the OEM radio and OEM amp?
If you can tap before the Bose amp, then you may only need a simple LOC. If you tap after the Bose amp, then you will need a bass restorer/LOC...
Sleeklsc
Sleeklsc
Sleeklsc
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
