New System Setup
ridge
With help from a car audio expert, here is the new system diagram I came up with. My Rockford bass setup was getting old and stock never cuts it for an audio system. Here's the diagram. Give me suggestions, experiences, praise, jokes, or whatever. Only rule: no flaming over my Sony deck; it does what I want. Thanks guys!
Looks good, just be careful using that much power to your subwoofer in that application.
RE's site says the rms power for the XXX is 1600 watts. Other people push more than that. I'm not really worried ab out the sub under 1500 watts rms. I'm more worried about my car's electrical system =/.
You'll be pushing that sub really hard if you have your gains up at all. XXX and Brahma are quite similar, and Brahma doesn't like that much power. Remember those thermal ratings. =o
who's the 'expert' that helped u
TL aka TurkeyLord. I believe his name is Jordan.
Hmm yeah. Now you have me thinking about a different amp. My friend killed his 12" Brahma with about 1000-1100 watts. The XXX, I've heard, can handle 2000 watts daily. The brahma didn't blow, the suspension just tore. I think the suspension on the XXX is better though.
Certainly depends on the vehicle and type of enclosure tuning for the subs and direction of the subs and port to begin with, then power...
7
191
For some extra peace of mind, you could do a big-3 upgrade with the same 4 guage ofc wire.
727
Disconnect the amp for a day or two, then connect it back up. If it stops draining when unplugged then drains again, take it back and have them...
I would also recommend checking all the amps wiring to make sure secured/ tight and ground is solid and remote making solid contact in the terminal
7
ridge
ridge
Minneapolis, MN
ridge
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
