No power to unit
surfrida
I have a weird situation, or maybe it is jsut weird to me. I recently installed a Clarion DXZ535 in my 1999 VW Jetta, everything worked fine for a month, and now when I start my car the unit doesn't power up. But, the weird thing is, when I turn my ignition switch right to the point before my engine fires, the Clarion powers up and then when the engine is started the Clarion powers off. I checked all the wiring and fuses and everything is fine. Any ideas what it could be?
Surfrida
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
https://www.taramps.com.br/en/produto/amplayer-400/
5
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Certainly depends on the vehicle and type of enclosure tuning for the subs and direction of the subs and port to begin with, then power...
7
191
If you are using an aftermarket headunit, make sure your subwoofer is set to 'on' in the settings menu
4
232
surfrida
surfrida
Pensacola
allyourblood
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
