noise from sub without RCA hooked in
  • 5
Imshirazy
dewd
300
CT
Hey guys, today when I turned the key to my car (car not fully on) even though my head unit had the volume fully turned down, i heard a slight rumble. I wasn't sure where it was coming from so i checked all my speakers, it was the sub.
The sub was playing a non stop solid note, no idea what hertz the note was though, im sure that might be an important piece of data though...
Only the sub was making the sound and no speakers, so i unplugged the RCA to see if it was head unit related, but nothing changed at all, not even a slight stop in sound when i unplugged the sub RCA.
My sub is an alpine swx-1042d and hooked to an autotek sx-777 (7 channel amp)
what could be causing this? It doesnt do it when the car is off so it's at least not like the amp stays on
and i think it might do it do even when the car is on but the car volume is louder than the rumble and i didnt check, but the music still plays crystal clear even through the sub, what could this be?
Could be multiple things. I don't know a LOT about amps. Sounds like it could be a ground or something going bad in the amp but AGAIN I am no amp expert. Also can be many other things. but those are the first things I would look at
Im sorry, I didnt read your post, but I dont think I need to. If the sub is outputting sound even with no signal going to the amp (RCA's disconnected), you have one of 3 problems... 1) poor connection/ground for the amplifier, 2) the amplifier is mounted directly to metal (shouldn't be), or 3) a speaker wire has come loose. Its probably number 1 or 2.
You have read the whine-and-ground-loop sticky here, right? I've only had alternator whine in one install, and it was nearly impossible to...
12
475
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Imshirazy
dewd
Imshirazy
CT
Echo42987
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
