noise problem
lOl_olo
Registered User
I recently wired up my us acoustics amp to my front components, not to long after I noticed that i could hear a click every time i changed the volume on my deck, and at high levels the front right speaker distorts. I checked the wiring on this speaker and it looks good.
I know that the amp is working fine because i had it connected to my subs before I switched it over to the front speakers. I have gone back through all of my wiring and it all apears to be. Could someone please give me some ideas on what to try, and what could be causing the problem.
Look at you LPF/HPF and insure you have it switched to the right position. I am not really up to speed on that amp and its abilities, but also (if it does have the HPF LPF check to insure they are set correctly).
I was looking today behind the dash to llok at the wires..I have absolutelly no idea what they are for .i know only power 12V,ACC and ground ..the...
4
435
Antenna. Forgot to connect the antenna adapter. That may be the reason for static.
Not sure. I’ll have to try that. Then I can disconnect those. Could use some sort of battery led then. Will try that tomorrow. I am tired to...
9
371
You have read the whine-and-ground-loop sticky here, right? I've only had alternator whine in one install, and it was nearly impossible to...
12
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
lOl_olo
Registered User
lOl_olo
camano island
pavengmike6
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
