ok guys, im desperate....
Tell me how you take a video of clipping?
Hey smartass he said it not me. I read that he meant his subs were distorting...I'm just trying to help the guy out here...WTF is wrong with you?
I know WTF clipping is...are you like the word police are something?
Subwoofers don't clip, it's the amp being overdriven...turn down the gains until you don't hear it anymore, or find someone with an oscilloscope and set your levels properly...
Everyone can cut the childish **** out, it's not welcome or appreciated here.
Agreed...the smart ones can actually know what the OP was asking (even though he didn't use the correct terms) and actually try to help him rather then posting nonsense...
yes, thats what I ment...the subs will not get loud at all and just distort beyond all belief (aka the amp is clipping)..........the subs are in perfect working order, and wired so the amp sees a 1.2 ohm load with the dmm..................
So as to avoid a long list of suggestions...can you post what you've already tried?
Have you narrowed the issue down to the subs? If so how? For example you swapped in a buddies sub and it had no issues, etc...
no, the subs are fine..........the h/u is fine......amp is recieving good voltage and everything is wired ok....could this be from a bad ground? And if so, why all of a sudden?
Me too and then I have to paddle anywhere I want to go.
6
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
those center spots shine out pretty far enabling me to see well on the dark highways.
22
3K
BIGsherm7272
Tampa, FL
JohnBlayz142
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
