Painting My Box ??
brandontw
just some guy
2,997
Reno, NV
I just built a box for a couple Cerwin Vega 12D4's and im pretty happy with the way it turned out but now I am contemplating covering it. I think i would like to just paint it flat black instead of carpeting it, is it ok to do this? I plan on just using some spray primer and then some spray paint.
Will the spray paint soak into the MDF too much and make it mushy like water does? And i want to make the box water resistant cause my trunk gets a lot of use; will lots of primer and paint do this?
Any advice would be appreciated. //content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif :up2someth
Painting's fine. Make sure the enclosure is perfectly smooth--use Bondo or wood filler & sand smooth:
I chose bedliner or my enclosure's finish (available at WalMar):
With bedliner, you're essentially coating the enclosure with plastic. Moisture won't penetrate the MDF. Neither will paint, FYI. I sprayed black paint for a lot of the non-surface areas:
That box looks nice, makes me want to change what i'm doing to mine.
I have one coat of Stone Creations paint on, but the MDF is soaking it up a bit. I think after 2 coats it'll be fine though.
Thanks for the idea! thats exactly what i wanted. Can i primer before i coat it or should i just throw it right on the mdf? and is it paintable
1.3cuft isn't enough airspace. Shredders box plans are simple enough if you want to save a couple bucks.
10
174
FEATURED Sniper Box
6th order series bandpass tuned to the vehicle resonant frequency. Basically a one hit wonder box.
266
https://www.ebay.com/p/3025988078?iid=302622841801 This was for a 15" but i liked it until i toasted the sub.
11
655
Have you checked out these shallow drivers from DD? A friend had 4 of them and man, it took it to the house for what they are...
6
567
My guess is, once you get the speaker in it, more like 34hz so good to go. With that unit, try it up, try it to the rear, see which works best...
12
772
brandontw
just some guy
brandontw
Reno, NV
brandontw
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
