Planet Audio D class!!!!
Dozer
I just got a planet audio p850d mono amp.....it says it is 1 ohm stable....but I have no experience with them....does anyone out there have one and ran it at 1 ohm??? Any feedback on this amp would be appreciated....i have never used PA stuff but several people recomended it so I decided to give it a shot!!! Any PA feedback would help.....thanks!!!
Also.....I have yet to get my new subs and am still using an audiobahn dual bandpass box...svc 4ohm....would it be ok to run that at 2 ohms with the pa amp ??? If I run it parallel it would be a 2 ohm load from the amp and I don't want to blow the speakers as I am going to sell them.......but if i run it at 8 ohms in Series then it is barly any powere??!!! how should I run this box?? It is 600 watts rms...300 each sub....4ohm svc......thank you....I know this is probably a stupid question but im new!!!!
If your sub is 4ohm svc, then it would be 4 ohms at the amp. Unless you have 2 subs, then it would be 2 ohms at the amp.
Keep the gains low and dont bang on them too hard if your going to sell them.
BIll T.
Thanks...yea i have 2 subs 4 ohm svc.....I have them wired in parallel which should be a 2 ohm load at the amp....... amp + to the +of one sub and - at the amp to the - of that same sub.....then wiring the - to the - on the sub on the other side....same with the +........is that right? Anyway it seems to be working well...getting plenty of power and I have the gain about 60 to 65% ..........thanks
https://www.amazon.com/dp/B0B3X3C7RD/?tag=caraudiocom-20 This is one of the better reviewed budget touchscreens. I just about pulled the trigger...
557
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
my RE SE ($200) graphs (using BBP) lay right on top of the 12w6v2 graphs JLs good stuff but $$$
128
Dozer
Dozer
Boise, Idaho
ghs_wrestler189
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
