Please help !!!!
Orionslave
OK to start I have 2 orion 275 xtr's and I just purchased 2 audiobahn 1208T's duel 2OHM voice coils. I am planning on running 1 orions amp to each sub. Can anyone give me the proper wireing ? I do not know if the amps are stable to .5 OHM's or not and if they are not then how would you wire 1 amp to 1 sub?
If any other information is needed to help you answer PLEASE POST
Those amps are 2 ohm stereo and 4 ohm mono stable. Great amps, too.
You will need to run a wire from the pos terminal of the amps left channel to the pos terminal of one of the coils on the sub. Run another wire from that coil's neg terminal to the pos terminal of that sub's other coil. Finally run a wire from that coil's neg terminal to the amps neg on the right channel. Do that for each sub amp combo. That will give you a 4 ohm bridged load and at least 300W to each sub.
They are under rated and will put out more than their rated 300 watts when bridged, but you can't drop the impedance on them or anything crazy like that to get more power out of them. They are old school amps made for running high freq speakers or a small sub. The 2150 and the HCCA series were meant for subs at higher power levels.
Which series amps are they? Do they have the removable plate on the top with the filter cards underneath?
i just got them a couple of weeks ago i was hoping i could use them 1 per sub on my adiobahn 12" but teh subs are 3000w RMS with duel 2 ohm coils
Damn straight. I had one in a 1 cube ported to 35 Hz iirc. It was not that deep but played everything I liked with authority. They were Kove's...
8
539
You indicate it was installed? Why did the installer not go over the settings with you? They didn't set everything up? What is the system? Did...
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
Orionslave
Orionslave
29Palms Ca
Orionslave
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
