port placement??
Beermakesmehoppy
I have an 02 F250 Crew Cab and built a custom box behind the rear seats. Each chamber is around 1 cu. ft. As of now it is a sealed box but I want to port it. There is only one thing, the box demensions are roughly: 56" wide, 8" deep bottom, 4: deep top, 18" tall. The only location for ports are vertical somewhere on top of the box
box in truck
any suuggestions???
thanks
There isnt a problem with firing the ports up as you described, but I would recommend more than 1 cube if your going to port it. Check the JL spec out for what would work best as far as volume and port displacment.
Use to be a popular setup in the s10 trucks used in competition....most were well over 150dbs ....
4
589
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
InhumanAcura
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
