Power Acoustic 12fubr
if this helps any my friend had 2 15 of those an they couldnt even handle 600w rms each so i would recommend an 1000-1200 watt amp but watch the gains my friend was using my jbl 1200.1 so that wouldnt be a bad choice for an amp but once again just watch ur gains an volumes....that is an very over rated sub
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
Certainly depends on the vehicle and type of enclosure tuning for the subs and direction of the subs and port to begin with, then power...
7
191
If you are using an aftermarket headunit, make sure your subwoofer is set to 'on' in the settings menu
4
232
https://www.amazon.com/dp/B0B3X3C7RD/?tag=caraudiocom-20 This is one of the better reviewed budget touchscreens. I just about pulled the trigger...
556
HANGIN2001
HANGIN2001
VIRGINIA
callahanianhunk
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
