PPI PC650 blown amp, help
Breogan24
NYC
recently sent to repair a PC650. The guy repairing it said that it blew all the output and power supply ICs , as well as 2 regulator ICs. Now my question is what could have caused this? I was just using the rear channels and sub channels bridged for 2 JLw3's. It ran fine for a month and then the unit would power on and off by itself repeatedly. I am just trying to avoid screwing it up since it will be repaired now.
Thanx in advance.
PS, the subs were wired at 3 ohms, and also i called PPI to ask them about this, but i think the guy i spoke with was lost. He told me that since I was only using 4 of the 6 channels my amp was producing too much heat and caused all my ICs to blow. Sounds like BS to me.
Pro competition level 4 channel car audio amplifier. Highly under rated, produces way more than the rated wattage. Very low hours, taken from...
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
4K
I am wondering if anyone has heard or have information on the new PPI vertical PC amps. Are they good for a budget sq class D amplifier. Any...
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
Breogan24
Breogan24
NYC
Breogan24
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
