****!! problems with CDT TWEETERS!
xploit2
I just got a pair of CDT-CL61 and the tweeeters are smaller than my prevous ones the ones I had before were 1" these seem to be smaller what can I do guys?? //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
i was looking at maybe getting the cl61a's, do they come with the 1" or .75" tweeter??
Is there much of a difference or are they similar..
About a month ago I talked to CDT and they were selling their 1" silk dome tweeters for $50 a pair... these are the tweeters that come with the HD-62 set, and they are incredible.
Or else you could get some ABS plastic and cut circle big enough to cover the hole in your doors, then cut a circle in the middle of that to mount your new tweeters in.
where did you see those tweeters at pete?? thanks for the help guys I been busy at work so havent had a chance to check the replys sorry it took so long //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think they are smaller the .75
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
xploit2
xploit2
california
Pete
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
