Fritzy
I am working on rewiring the speakers in a houseboat and I was wondering if it was possible to use a home audio speaker switch/volume control in a car audio environment. I was hoping to use a 5 speaker pair switch so that I can independently control the speakers in different areas of the boat and well as turn off speakers when not in use.
One i found was the TEC-905B with the following specs:
Dual source inputs
Five speaker pairs output
Each pair of speakers can be alternatively switched to either amplifier A or B
Accepts up to 12 gauge speaker wire via gold plated banana socket connections
Frequency response: 20 Hz to 20 kHz
High efficiency transformer based designed, fully automatic amplifier impedance protection
Compatible impedance with 4 - 16 ohm speakers
100W RMS, 200W peak per channel power handling
Individual rotary volume controls
Master ON/OFF switch connects and disconnects the signal distribution from the amplifiers to the speakers
Dimensions: 2.25"H x 15.5"L x 8.5"W
Weight : 12 lb
Headphone input with volume control
Pre-printed zone and equipment list label included for easy speaker connection identification
Sturdy metal enclosure
Passive design, no power required
I was contemplating using a 100X2 RMS amp with this switch. Does this seem possible or does anyone know of a switch/volume control that is geared towards car audio?
Thanks for any help people can give.
Dual source inputs
Weight : 12 lb
