Question about PG T1200?
I have a PG Tantrum 1200.1. They do not reccomend running this amp at 1 ohm. I am running this amp at 4 ohms right now and am enjoying it very much. If you decide to go with the JBL 1200.1 then you will need to invest in a ssf, there is not one built in like there is in the Tantrum.
what will you be running with the amp?
If you are running a dual 2 ohm VC you can just run it at 4 ohms and get about 1400 RMS from that amp. If you are running a single 2/4 ohm VC you will be fine, 2 dual 4's can be run at 1 or 4 ohms, so pick 4, adn 2 dual 2's can be run at 1/2, 2, 8 so pick 2.
It is an extremely versitile amp. You should be fine with almost any setup.
Thanks. That was my ending thought as well but didn’t think of it! Thats why I’m just an ole boy and not a programmer! Thanks for the reply...
316
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
647
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
833
https://www.amazon.com/dp/B0CJB5TTPB/?tag=caraudiocom-20
8
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
Jt321
Jt321
Surprise, AZ
helotaxi
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
