Question.
creary21
I have a question, it might be a dumb one but I am stumped. My truck got wrecked in an accident, and it was getting fixed so i just took the deck out and we were going to put it in my friends truck because his got broken into and they took his deck. So we just cut the harness when we took it out, and then after my truck was fixed, we hooked the head unit up color - color, as right as it was before, and the deck wasn't working. I took some time and did some thinking, and just did it again, except i hooked up the antenae wire and it got power to it....i do not know why its working but it is. So if somebody could tell me why my deck only works when the antenae cable is plugged in that would be sweet. But now that my deck is up and running, my speakers aren't working? I don't know what the problem there is. All of my amps are working, but my factory speakers in the dash and door, nothing comes out of them. Could it be the coils are blown? I need some help?
Thanks
your antenna is grounding the deck, recheck the main ground it may not be sufficiently secured to allow the deck to power and the antenna adds just enough to get is working.
this is also not a speaker question
thanks, thats exactly what i thought about it acting as the ground, but it kind of is a speaker question because i was asking why they wouldn't be working also. But thanks for your help. i'll try that out.
Thanks. That was my ending thought as well but didn’t think of it! Thats why I’m just an ole boy and not a programmer! Thanks for the reply...
316
Use any negative terminal or positive terminal slot out of the amplifier outputs or speaker outputs. Only one positive and one negative should be...
649
I talk about these boxes a lot, maybe cause Im biased, but they are just great boxes...
12
834
https://www.amazon.com/dp/B0CJB5TTPB/?tag=caraudiocom-20
8
LOL - mine was a higher end model too - iirc deh-9300. Low mileage too, it was sitting around for year collecting dust.
7
creary21
creary21
Saskatchewan
DBfan187
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
