Quick dampening question
As long as your applying it directly to the sheet metal it shouldn't matter. But personally I would install underneath just to make it easier to hide afterwards. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I think if you put it under the rear deck, then dont install it upside down. I think this will prevent your amp from cooling off properly and can cause it to overheat.
Damplifier not an amplifier. ie noise dampening.
so should i go under the rear deck? I have already taken the material off the top of it so i can access it...although it may be hard to put back on if i put dampening on the top.
It truly doesn't matter for effectiveness. It's a matter of what is convenient for you, and how well you can hide it. If the thickness prevents you from putting the deck back together, then do the bottom instead. Otherwise, whatever is easier.
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
i have no experience with component speakers. Maybe someone else can help in this area.
Thanks. That was my ending thought as well but didn’t think of it! Thats why I’m just an ole boy and not a programmer! Thanks for the reply...
316
williams22
williams22
Vermont
Breogan24
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
