QUICK help on L7 install
tylermac21
13
NC
I have to finish the installation of my 2 L7's today, i did my term paper on car audio :) and my presentation is in two days.....my amp is installed, my box built, but im stuck when it comes to speaker wire. Im wiring them down to 1 ohm, and since the subs are 4 ohm the wiring config. is parallel/parallel......i bought 12 g. speaker wire but the negative side of the wire will not go thru the terminal because the insulation is square; however, the positive went thru fine, since it is circular. Why is this? Can I still use this 12 g. wire, and if so, what should i do to get it to work? Can I just use 14 g.?......btw the speaker wire is lightning audio.
nevermind, i figured it out and got it installed.....now i have to figure out how to keep the CD player from skipping when the bass hits.
i have no experience with component speakers. Maybe someone else can help in this area.
Yeah, I can't find gold connectors anywhere online anymore. Amazon Canada only carries brass or "red" copper. I was gonna get the Glark's set with...
tylermac21
tylermac21
NC
tylermac21
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
