RCA's big problem
you asked this a few days back. cyberbob already answered you. in case you forgot, here's his answer again:
"If your amp doesn't have a high level input, then you need to buy a low level converter (LLC). Just like before, you must run the wire currently going into your speakers into this converter (again, if using for subs, you can just tap off of your rear two speakers). Then run an RCA cable from the LLC to your amp."
abe m.
X2 on the front amp. If you just want to use the BT, then you do not need to use the radio. In my home stereo, I have a rechargable BT dongle for...
78
If you have the manual for your car Ford Flex, look up where the factory amplifier is located. The wires going into and out of the amplifier...
6
422
Thank you so very much I will make I happen an get back o you on outcome..THANKS again!!!!!
510
https://www.amazon.com/dp/B0CJB5TTPB/?tag=caraudiocom-20
8
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
fusion
fusion
barrie,ontario
allyourblood
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
