UUUUMMMMMM No, definately not perhaps you should stick to audio smart one.
Everything will be magnifluxed (checking for cracks) if everyting is cool the rods will be resized the pistons will be replaced with a larger overbore piston. The block will be redecked and rebored. The crank will be turned to like new condition and rebalanced (some cranks are internally balanced, pont. 400). the cams will 9/10 not be replaced. All new gaskets and the head or heads will be milled to ensure proper sealing of the headgasket (ensures correct compression ratio). Thats pretty much it, sometimes the oil pump is replaced.
