Removable Port
BooLeaN
Hello, I am considering making a removable port for my box. Right now it is 5 cubic feet, tuned to 36 hz for 1 RE HC 15. The 5 is after displacements. My port opening is 15.5 X 4 inches. I am thinking about tuning it lower for daily, somewhere around 30-32. The depth of the port is 16"
My Question is, how do I do this? If I make the port 15.5 X 3.25 will that make the tuning higher or lower? If so, I could just add a piece of wood into the port so it is 15.5 X 3.25 instead of X 4. Also, does anyone have a good suggestion as to how I can make the wood secure but easily removable? I want to have it so it is reversable fairly easily.
Thanks,
Craig G
Thanks,
Craig G
make a plug that fits into the port that is longer and has slightly less surface area. you can secure the plug to the box with T-Nuts
Look at the JVC brand. I have an older unit with a removable face plate. Model KW-AV61BT. Contact Crutchfield.com support for some current...
Use to be a popular setup in the s10 trucks used in competition....most were well over 150dbs ....
4
589
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
BooLeaN
BooLeaN
Canada Ontario
BooLeaN
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
