Replacing door speakers 96 4 runner
thenewguy
AL
I have a 96 4 runner and i was wanting to replace my door speakers decided to mess with it and try myself first took the arm rest off and took two screws off then i took the two circular things with pins in them and i was able to get the bottom half to pop out but its still connected to the top half of the door im able to pull it back far enough to see the speaker and all but I cant get my screw driver in there to take all 5 screws out... this is such a ***** I have run wires all through my car put in a new pioneer cd player and installed a 1200 watt amp why the hell is this so hard to do. seems so simple anyone ever takin door panel off?
Does the door panel snap down onto the door frame. Try lifting up the door panel up off the door frame. It may just be hanging there kind of clipped in...
You tap into the 3.5s and the 6x9s then use the summing feature. This will sum the 3.5 and 6x9 frequencies into a full range output.
609
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Couldn't say which is preferable, ask Crutchfield, they have a cheat setup that is helpful for that info. Many a single HU's available. If you;re...
All things being equal in comparing speakers on the same amplification, the difference in overall volume will be slightly less with a same...
9
759
thenewguy
thenewguy
AL
Rockman
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
