running 1vc of a 2vc sub
I do not see what you say it is bad to only use one voice coil on a DVC sub. I have been installing for 20 years and never heard that. I have NEVER had a problem with only using one VC.
I will give you that it is not the most effective way to use the speaker, but damage is not going to happen.
using a single vc wont damage the speaker itself but remember most dvc are rated rms by combined coils, your power handling will therefore be cut in half
not to mention it wont be as loud
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
913
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
LBX2G
R.I.P Camofluage
LBX2G
Warner Robins
LBX2G
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
