running components off of deck
97acuratl
Im trying to plan my system out and im lookin for some info with my setup. basically im goin to put in some phoenix gold qx components in the front and some cheaper 6X9's for the back.
I dont think i can afford to get an amp right now so im wondering if the clarion deck that has 18rms per chanel will sound decent for the time being on those speakers. im not into crazy loud but im just concerned if it would be enough power for the speakers. Like would they distort at lower volumes or anything like that?
Thanks for any help!
a friend of mine is powering his comps with his hu untill he gets an amp... its ok, dont worry about it, although id suggest u ditch the 6x9s and use the money u save on that for an amp later on.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
914
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
97acuratl
97acuratl
Saskatoon, SK
triphop
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
